Aqvox USB Linear Power Supply - Type A
Low-Noise 5V Isolated Linear Power Supply— For USB DACs or USB-Devices USB Audio interfaces
£50 delivered by RM 1st class signed for.
Thanks Paul- I'll have that if ok with you.
Will send PM
That was quick! Thanks Edward.
Good luck with the hack. I've replied to your pm now.
Could I recommend to mate it to the card with a female usb socket plus some wiring I get upset when I see nice PSUs hacked to fit? Holds it's value better as well
I'll try my best Lawrence. I'll sus out what to do when I get it. CPC will likely have something to fit. Or just use any old USB cable I have lying around. Plenty in the glovebox in the car. I already have the screw-in connector for the computer side.
Don't want to upset you Lawrence.
Paul
Just to say thanks for the PSU which arrived today. Really well packed.
Did not have to hack things around on the PSU. Just used a spare USB cable, snipped that and wired it to the Paul Pang USB card.
All working. Need to settle the USB card for a while as it has not been used for about 2 years.
The PSU measures a steady 5.1v
Thanks for the update Edward. I'm glad it arrived safely and that you found a way to use it without hacking it about. I hope it works out well for you from a sq perspective.
