Ebony. Just to be posh. It is just beautiful stuff to work with too, dense as hell. You want it it to deaden sound, right?
Maple is used with much success by some manufacturers of “chopping block” style turntable supports, and is a nice tight grained wood. Also used in instrument construction, rock maple is often used for bass necks, because it doesn’t ring. And it’s not too rare so it should be affordable and easy to find. And it finishes nicely, a simple oil finish is all that’s needed. If fancy is what you want, get some birds eye maple!
This kind of question crops up quite frequently and when it does there are always plenty of answers stating that certain types of wood are used for certain bits of musical instruments - but so what? What has the neck of a bass guitar or the soundboard of a piano got to do with it?
For example, the neck of a bass guitar is under a lot of tension and has to be able to withstand it, so wood is chosen accordingly. Even then, the neck has to be reinforced with a truss rod. The neck of a classical guitar is under a lot less tension and is a lot shorter, wider and thicker, so it doesn't have to be as strong and lighter wood is usually chosen.
Ebony is used for fingerboards because it is very hard-wearing, not for any particular sonic properties.
Anyway, the point is that musical instruments are not feet for hi-fi components so choosing the same wood really doesn't make any sense.
Just use whatever wood you like the look of, that turns well and you have available.
Lacquered spruce is what Altmann uses.
I use ebony and bamboo extensively.
I'm brian.
Ikea bamboo butchers block have worked really well in my system. Great review on the beat ? website.
You woodn't belive it but this discussion is sapping my strength, of course I think you're all barking up the wrong tree and it rather goes against the grain....
just saying
/coat
Let’s not let anymore puns take root please.
