Lenco GL75
IMG_2903.jpgIMG_2895.jpgIMG_2905.jpgIMG_2897.jpgIMG_2899.jpgIMG_2903.jpgIMG_2895.jpgIMG_2905.jpgIMG_2897.jpgIMG_2899.jpg
I have a GL75 for sale ..
The deck has been fully serviced and plays very very nicely. It has the original lid that has only a couple of minor marks , and the wood work is very very nice too ..
It has A custom Carbon fibre arm,( carbon fibre with alloy core , wired with 0.2 mm 100% pure silver ,silk covered wires .. ) a pair of Brass Vee Blocks and a Lenco lightweight headshell .
I have ditched the original pants ( technical term ! ) phono leads and Lenco connection block which is normally mounted under the platter , and have wired the arm directly to a pair or Audio Note silver phono sockets on a carbon fibre plate . This will allow the buyer to chose the grade of Phono leads he uses ..
The deck also has a 5 hole idler pulley .. polished platter edge and new power lead ..
and is fitted with a Goldring G800 cartridge with new stylus ..
The deck looks and sounds great , will post at cost or buyer can collect and audition ..
I'm looking for £300 plus postage ..
PM sent
Brian,
Having heard one of your 75s at Brian's Id be happy to take stewardship if its still available.
Cheers,
Tony.
- You may not post replies
- You may not edit your posts
Forum Rules
