Results 21 to 30 of 35
Thread: Did anyone use Moth record cleaning machine MKI version
  1. #21
    I'm Graham.
    BTW BP water = British. EP water = European just to save any confusion,there both the same quality.There are many reputable DI manufacturer's ,but also many who are not,I once measured a Hydrochloric acid level of 2% in the product water at one site,the client didn't give a toss and was still selling it on,if DI plants aren't serviced the diaphragm's in the chemical line valves disintegrate and the resin requires replacing every few years,IME if this doesn't happen it can lead to all manner of problems.
    At BP/EP sites if I found a problem they would shut the plant down,rectify whatever needed fixing and re-validate before going back into production after the water had been had been tested by an Independent laboratory.
    Analogue. Basis signature 2200,Basis Vector 4.Koetsu Red,Koetsu SUT,NVO SPA 11.
    Digital. Denon 2900,Jolida FX 11
    Amp. Pathos Logos,Minidsp dirac 22A.
    Speakers. Amphion Xenon.
    Airlink CBS 2000 bps
  2. #22
    british pharmaceutical
    I'm Graham.
    British or European,they all have to comply with the American FDA specification's.
  4. #24
    I'm Brook.
    I use a mix of RO water & L'Art du Son, no surfactant needed. I use RO (reverse osmosis) water in preference to DI because it is much purer, & has the benefit of being cheap, £2 for 20 litres from tropical/marine fish shops.
  5. #25
    I'm Graham.
    Quote Originally Posted by speedracer View Post
    RO is preferable to DI as it can remove up to 98% of the bacteria present which DI doesn't,how ever unless you know what the conductivity ( measured in micro siemens the lower the better ) is then again you will have know idea what you are buying,RO membranes also require maintenance and replacing otherwise they can fail.
  6. #26
    I'm Peter.
    i had to sell my moth as it was very noisy
    I bought it. Sorry, did you say something?
  7. #27
    I'm brian.
    I have one, dont know if its mk 1 or 2. it goes both directions
    Yes, it gets hot, but by that time Im bored anyway, so just stop. I think that would be about 20 sides or so.
    it is noisy. I use headphones when I use mine.
    your price seems very good.
  8. #28
    I'm Allen.
    Quote Originally Posted by petrat View Post
    WHAT ?
  9. #29
    I'm Bikram.
    Just picked up today...
  10. #30
    I use contact lens solution for cleaning on my Moth. I have a endless supply as I never use it all with my lenses.
    If its good enough for you eyes its good enough for records.
Tags for this Thread
