Results 11 to 20 of 27
Thread: Joined the Linn Club
    I'm gone.
    Try a soft (eg camel hair) brush on the laser lens - might just be a bit of muck / dust.
    That worked for a CD Walkman type device of a friend of mine with similar problems.
    I'm Dan.
    Hi Jerry
    Thank you its a weird one maybe its a worn disc that i have had for many years but plays on other CD players fine - The Classik maybe is sensitive but it has played a couple of albums fine this afternoon - OMD & Emily Barker without fault but worth looking into your suggestion and many thanks..
    Cheers
    Daniel
    Bi Amplification
    Quad 33 with current Mod for CD
    2 Quad 303 Bi Amped
    Turntable
    CD Transport & DAC & PSU
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
    Cleaning might clear the problem, but don't use a cleaning cd as some of them will wreck the optics and they don't work in any case.
    I'm Dan.
    Cheers Martin , Couple of quick ones RE jumping the Tukan's i dont have the plates to single wire them - can i jump them with bare wire or does anyone have the metal plates?
    Bi Amplification
    2 Quad 303 Bi Amped
    Turntable
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
    You can use bare wire, it will do the same job. But it will oxidise over time and need stripping back.
    I'm Dan.
    Cleaned the Laser and the result is still the same so its a faulty laser - i can buy a new one from eBay but who can i get to fit it? All my local guys have retired
    Please advice...
    Bi Amplification
    2 Quad 303 Bi Amped
    Turntable
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
    clean the carriage rails and then re graphite them(what the laser moves on). possibly that causing it
    I'm Dan.
    Interesting grant will give it a go...
    Thank you
    Bi Amplification
    2 Quad 303 Bi Amped
    Turntable
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
    I'm Rich.
    Quote Originally Posted by dantheman91 View Post
    It's a bit of a long shot, but if keilidh wiring plates are the same fit and I can find the ones I'm sure I have somewhere you are welcome to have them.
    Clearaudio Emotion with Clearaudio Performer cart
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    Van Damme I/Cs and cables
    I'm paul.
    Couple of days of testing and the Classik has the usual skipping like a tonearm fault but only on track 1 of each CD i play? could it be DUST on the laser which laser cleaning discs are best or worth an attempt to clean my self If not off to an engineer to see what can be done excellent sounding kit and moving stuff on to justify keep it Tukan are a real Jem also...
    why haven't you asked your Linn special friends Dan
