Page 6 of 20 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 197
Thread: Technics SP10 MK2 nearly ready!!!!
  1. #51
    Bigman80 Guest
    Was thinking of putting some sound deadening sheet I've got on top until I decide what to do.
  2. #52
    I'm Kevin.
    Funk Bo!ng feet?
    Kevin
  3. #53
    would agree, it will probably be the shelf being slightly alive. feet wont be helping. The levitating ones only isolate in 1 dimension
    Bigman80 Guest
    Great point, Grant. I think Isonoe may be the way forward but I'd need some hefty versions!
  5. #55
    If you're not tapping the shelf while listening to a record I don't see there is a problem. Nothing that happens in normal use will replicate that effect.
  6. #56
    Bigman80 Guest
    Just worried about resonance as it's quite close to the speakers
  7. #57
    I'm Peter.
    Yes indeed Grant...... downwards only (into the shelf). the Slate shelf will cost you less that £50 and if the correct Blue Slate......it is very dead indeed. (the devils material)
  8. #58
    Some acoustic feedback is inevitable unless you put deck and speakers in different rooms and then you might find you don't like the subjective effect of having zero acoustic feedback...A cartridge is effectively a microphone. Even if you use a chunk of armour plate from the Bismark for a shelf you can't get round that.
    Won't hurt to beef up the shelf I suppose but if it is already sounding clean and precise it doesn't seem like you have a problem to me.
  9. #59
    I'm Adrian.
    I get the tiniest bit of feedback from the granite table, and even less from the plinth. Zero from the sp10 itself. Use a stethoscope you check - cheap on eBay.
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
  10. #60
    Quote Originally Posted by farflungstar View Post
    And when you've done that you can wear it round the house and pretend to be 'Doctor At Large'. IME most women have a thing for Doctors.
