Results 1 to 10 of 20
Thread: HDPlex linear PSU has blown up my SEG!
    I'm Gareth.
    Default HDPlex linear PSU has blown up my SEG!
    Is 15.27v sufficient to cause damage to my SEG?
    Installed a HDPlex linear PSU this morning and hooked the SEG to the DC19V output that I’d internally adjusted all the way down to 15.27v (won’t go any lower). After approx. 30mins lots of smoke pouring from the Caiman. Unplugged it all, whipped off the top to reveal a blown capacitor and a certain amount of wetness inside:
    https://imgur.com/gallery/ddnsk
    Not happy to say the least and very concerned about the risk of more serious damage (i.e. ignition and fire).
    Any advice gratefully received.
    I'm Gareth.
    And my RPi3 and my Roku Premiere+
    FFS
    I'm gone.
    Oh no.
    Cripes.
    Nightmare.
    Must have been putting out more than the seg can take. Put a metre across the plug and see what's really coming out of it
    I'm Gareth.
    I did measure the output voltages before plugging everything in:
    Fixed 5v = 5.25v
    Fixed 12v = 12.25v
    Variable 5v-19v = 12.1v
    Variable 15v-19v = 15.27v
    Checked and rechecked and when plugging in the Roku, it sparked and bizarrely the RPi3 went up in smoke. Roku also fails to power on now.
    Turning into an expensive day
    Deffo dc
    I'm Gareth.
    Yep, definitely DC. Unless I have seriously misunderstood it’s capabilities, I’m at a loss to understand why it’s all gone wrong.
    RMA request made.
    Got the tips right way round I take it. I would also check for ac in case
    This suggests a case of incorrect polarity arriving at the Dc connector. The Caiman as I see is designed for its own power supply
    so much caution needed connecting anything else.
    However it should also if well designed for the real world have either a forward biased diode, meaning that it is connected with anode in cathode out to the supply, or a shunt diode meaning anode to ground and cathode to supply. The part that has failed internally is likely to be the capacitor seeing reverse polarity ( without a diode ) which aside from leaking its electrolyte can also explode, however it looks like SEG Caiman have fitted a resistor which is the part that caused the smoke and this has limited the current. So slightly messy, but unlikely to have totally damaged the unit, rather replacement of parts, or the power supply section itself.
    Slightly over 15 volts really should not have caused any damage, but I would need to see a schematic to confirm.
    A good electronics shop could repair, but better return to SEG Caiman, who will either replace under warranty ( maybe ? )
    or fit a new power supply.
    So it does not happen again once it is repaired , you need to fit a forward biased diode inline. This will involve modifying the cable to have a diode fitted. The diode slightly drops the voltage too. The diode needs to be rated to well within the current rating drawn by the SEG Caiman
    and its voltage too needs to be considered, although voltage is easily normally catered for- as its hard finding a diode rated under 100v.
    Cheers / Chris
    Quote Originally Posted by Light Dependant Resistor View Post
    Cheers / Chris
    Yup i asked about the tip but no reply so far.
