Results 21 to 30 of 45
Thread: Tidal - what a load of rubbish
  1. #21
    Default Tidal - what a load of rubbish
    Never had a trial before ?
    Sounds like you have been classes as having had one
    I'm Adam.
    Hi Ed. I signed up before for a Qobuz trial and managed to get whole
    Tracks... something has gone wonky matey..!
    "lack of passion is fatal"
  3. #23
    montesquieu Guest
    Quote Originally Posted by Edwardlon View Post
    Prompted by this thread I just signed up for the 15 day trail of Qobuz. I'll be uninstalling it pretty pronto.
    It is billed as a 15 day trial but it is a very crippled trial. Only 45 seconds per track, only 320 mp3 and many (I mean many) 404 errors. I installed the windows 64 bit app as well as the Android version. Whilst the android version saw my TV as a playback device it did not see its own app (on my Windows machine) as a playback device - so bang goes the idea the Android app can be used as a remote control - like Spotify does so well.
    Also the Windows app has no easy way of seeing/playing local content. It says go to the ooo menu and 'import' but there is no ooo menu.
    It did see my audio device drivers so that is a plus I guess.
    Worked ok for me and not time limited in any way (though a couple of tracks said there were no rights and access could be purchased which I thought was totally not the point of a streaming service).
    Sound is fine and no errors (on a Mac) and worked well with the Mac's core sound capability and out to the rBlink and my DAC. Didn't try it with mobile control.
    It's missing LOADS of stuff though, not even one full set of Bach cantatas to be had, notably poorer than Tidal in this regard. Definitely not the answer for a classical fan. A lot of French stuff but that's not really my bag.
    I made no attempt to play out local content as I have iTunes and JRiver installed for that (though JRiver sounds noticeably worse than it used to, I'm told by Hugo this is due to some upsampling behavior that you can no longer shut off - no longer possible to ensure that content is played out in whatever format you have saved locally, which is piss poor in my opinion, some high-handed technical type enforcing his narrow, pig-headed view on the user base. So need an alternative for that as well).
    Next stop Spotify which to be fair I probably haven't looked at for five years.
  4. #24
    I made no attempt to play out local content as I have iTunes and JRiver installed for that (though JRiver sounds noticeably worse than it used to, I'm told by Hugo this is due to some upsampling behavior that you can no longer shut off - no longer possible to ensure that content is played out in whatever format you have saved locally, which is piss poor in my opinion, some high-handed technical type enforcing his narrow, pig-headed view or the user base. So need an alternative for that as well).
    I'm using jriver23 and thought it sounded the best yet tbh.
    I'm Edward.
    I'll have another look but so far I can only play tracks up to 45 seconds. But the main issue is of course not being able to play anything above 320/MP3s (Redbook, 24/96 and 24/192 are listed but not selectable). The MP3 stream SQ is not great. Frankly 320/AAC or 320/OGG are much better quality but not offered.
  6. #26
    montesquieu Guest
    Yes it's Jriver 23. Hugo says he's stuck with 17 as in his view that was the best sounding one. I'm no expert and have only recall to go on (always dangerous) but seemed not quite right to me and definitely fell well short of the same music played AIFF format out of Jriver vs straight out of my transport into the same DAC. The raw CDs played on the transport were far more musical and detailed. Not at all what I expected.
  7. #27
    I'm Edward.
    Grant, I'm a long time JRiver user and get excellent results. Are you using the app to stream stuff like Spotify, Qobuz or Tidal? If so, how?
    I can use the app for streams that use http - for example http://www.radioparadise.com/m3u/aac-320.m3u - but not streaming services that a user can control such as ones I listed.
  8. #28
    Grant have you downloaded the x64bit addon for Jriver 23? its here- https://www.jriver.com/download.html
    I presume you're running a 64 bit operating system.
    Didn't even realise the standard Jriver is only 32bit 'til I got an email from them. Always wondered why Foobar sounded better on my gear, it runs 64 bit asio drivers.
    We are the love we leave behind.
  9. #29
    I'm Edward.
    <snip>
    <snip>
    Tom
    Not sure if the highlighted text relates to Itunes or JRiver? If JRiver then most definitely a user can change the sampling or not. The default is 'no change' but can be changed to anything one wants (subject to the DAC accepting the sample rate). Look in Tools under DSP and audio output functions.
  10. #30
    Yes it's the 64 Ive got. There is a special driver for it too but I stopped using it at some stage. Don't use aiff only flac and mostly ape now. There are a number of setting adjustments that can tailor it as well.
    If u use the special driver you might be able to run Spotify through it. Can't remember if it works. I now control Spotify from iPad and play from chrome canary for best sound
