Results 1 to 10 of 16
Thread: Wtd bnc to rca coax cable
    I'm peter.
    Default Wtd bnc to rca coax cable
    Looking for a bnc to rca digital coax cable 1m length
    What's out there
    HEGEL H100 integrated amp
    REGA rp6/exact cart
    REGA Apollo r CD
    NEAT ELITE SE loudspeakers
    BERESFORD bushmaster mk2 dac
    Powered by a DEBEN tracer battery
    Mc5000 klotz ms audio cables(cheers Brian).
    REGA couple 2 ics
    JEZ ARKLESS phono stage
    RUSS ANDREWS powermax mains cables
    ISOTEK POLARIS mains block
    ATLAS Speaker cables
    CREEK OBH21 SE head amp
    BRIANS silver hybrid ics
    Have you considered using a BNC to RCA Phono adaptor?
    ... Which you can get for a pound or so from any Malins store, that's what I have done. Works fine.
    I'm peter.
    Hi Geoff Okey dokey I will give that a try. Any discernible loss in sound quality as opposed to using a dedicated cable?
    Any advice would be greatly appreciated
    Ta
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    Quote Originally Posted by clarkey555 View Post
    Ta
    No.
    I'm peter.
    Alreet Geoff I will take on board your thoughts and give it a whirl
    Cheers mate
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    I'm peter.
    Thanks James it all helps HIGH FIVE
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    I'm gone.
    I'm peter.
    Thanks Jerry
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    I'm gone.
    I understand the audio nervosa issue about using a cr*p cheap adapter, but like Geoff says they really are just fine.
    I use RCA/XLR adapters in my current setup and they are as near as damn it transparent as far as I can tell.
    I've used those BNC adapters as well.
