Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Ultrasonic RCM - thoughts
    I'm Adrian.
    Default Ultrasonic RCM - thoughts
    There's a couple of ultrasonic RCMs on fleabay at the moment - any thoughts on this method as compared to the usual....
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    I'm Adrian.
    No one has an opinion on RCM's?
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I believe you need or should be trying for a high frequency transducer if going that way, and unfortunately they cost a lot. Its all about bubble size
    I'm Adrian.
    But are they any better than the usual method?
    http://www.ebay.pl/itm/302468491710
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    who knows; depends on who you talk to, but for extra cost i would say no. maybe quieter tho and cleaner if they dry them too. a moth bi directional cleans very well so it hard to imagine it getting much cleaner
    You can make your own for a few hundred quid. Why pay audioPHOOL prices for a glorified instrument cleaner?
    PRE
    There is some concern that damage can occur to the vinyl due to cavitation. One recent ex-Member, who had done some research into record cleaning, was quite adamant ultrasonic RCM were bad for the health of your records.
    I might be a good idea to learn if any professional record archivists use them.
    I have tried an ultrasonic cleaner and didn't find it any more effective than a Moth and therefore not good value IMO. Furthermore, I have used a Moth for 30 years and know it is perfectly safe.
    I'm Josie.
    Sounds good... 'Ultrasonic'. Great marketing.
    Not sure how it can be bad for records unless the surfactant somehow reacts to the ultrasonic thus damaging the record?
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    I'm Josie.
    +1 Dave... The Moth is very good indeed.
    Tannoyista.com
    Facebook
