Designed, developed, and manufactured in Denmark, the TDAI-2170 is a stylish integrated stereo amplifier that has set a new standard in sound. In addition to being fully digital and having flexible upgrade modules and RoomPerfect™ room correction technology, the TDAI-2170 provides the formula for a sound experience that has left critics and listeners astounded.
This ex-display amplifier has all three input modules fitted, allowing you to get the best from USB audio, high-end analogue audio and a 4k HDMI inputs. Comes supplied in original packaging with all supplied accessories, including the remote, setup microphone and stand.
TECHNICAL DETAILS
Power Rating: 2 x 170 W @ 4Ohm
Inputs: 2 x Analog Single Ended RCA, 2 x Coaxial Digital (≤192kHz / 24 bit), 4 x Optical Digital (≤ 96kHz / 24 bit)
Outputs: 1 x Coaxial Digital (96kHz / 24 bit), 1 x Single Ended Analog
Optional Modules (all fitted to this ex-display unit): 4K HDMI Module (≤192kHz/24 bit) CEC and ARC compatible, Streaming USB Input Module (≤384kHz/32 bit + DXD / DSD64 / DSD128), High-End Analog Input Module (3 x single ended / 1 x balanced)
Dimensions (HxWxD): 10 x 45 x 36 cm, 3.9 x 17.7 x 14.2 in
Weight: 8 kg / 17.6
