The TacT Millennium MK I, was released in 1998 as the first “truly” digital amplifier. In its third generation, this single chassis "power DAC" is packed with capabilities offered by no other preamplifer/amplifier/DAC. These capabilities include built-in digital audio signal processors for equalizers, crossovers, and time-delay adjustment, an improved clock system that provides a 6dB improvement in signal to noise and jitter reduction, a digital transceiver supporting 192kHz/24bits, a new asynchronous sample rate converter, and a DA converter with balanced output to allow the connection of subwoofers. In comparison to the Millennium MK II, the MK III is much more relaxed, dynamic, and has better front-to-back soundstage, layering, space between instruments, focus and bass solidity. Established as the baseline for realism, intimacy and transparency, the MK III upgrade removes another veil to better communicate the emotion in the music.
This amp is in excellent condition, supplied with original remote control.
