E.a.r. 868l/pl
Anybody got experience with any version of it?
Would it be a good match for a mark levinson no27 power amp?
The local dealer where i get the best price don't have one and it feels a bit cheap lending one from one seller and buying it from another..
The specs i can find that might matter is: 5V balanced output on the 868 and for the no27: 26db voltage gain and 50K ohms input impedance shunted by 1.5 nF. The speakers are 4 ohms.
Best regards / Edgar
You will have no problem with that combination. Back in the day we used to regularly sell EAR pre-amps with Levinson power-amps.
- You may not post replies
- You may not edit your posts
Forum Rules
