Both £137.99
I'm Allen.
Both £137.99
I'm Allen.
http://www.ebay.co.uk/itm/like/38126...1899735&crdt=0
these are good too.
I'm Allen.
Remember I need it to match a iMac and amazon music files please
i use it with a pc. has a standard square usb at back plus others and rca's out. v/c only works on headphone section. not tried it on mac but should say in spec. this and the Yang sheng are both excellent value
Hi Malcolm, the phones I have are about 70 ohm and are fine.
Not sure I get what you mean ? What type of sound do you like ? DAC's do have sound signatures as, I suppose, tone arm cartridges, do. And well, if the singer has a cold, you would very clearly hear it with a good DAC . I think maybe you should define A.) what your budget is and B) what you expect from a DAC. As I understand, this would be your first DAC ? And BtW. any recent DAC with a USB input will work with almost any Mac or PC unless otherwise stated.
I've got a Meridian Director which is excellent, almost analogue. They are a bit pricey but they do a cheaper Explorer which ought to be worth a look.
