Update:
The iFi 5V supply came two days earlier than expected. I have plugged it into the AlloBoss system and am using Radio Paradise as a sound source. I cannot tell the difference between the iFi and the stock Rpi ps.
R
Update:
R
I'm Luke.
I don't know if the iFi device requires a 'burn-in' but I'll do another test later this week. Please remember that all my comments relate to me and my equipment (and I'm nearly 70 years old!). The iFi is cheap enough for a 'punt' without breaking the bank.
On a side issue, last time I tried the AlloBoss/Audiophonics comparison I used Radio Paradise 320, and this time the difference between the two seemed less apparent. Not what I was expecting!
If you do try a battery pack I'd be most interested in your findings.
Thanks,
R
I found a mobile charger battery to be better than the iFi on my RPi3. Better still is the Sbooster I've just put in the system today. I tried the 5V supply from my HDPLEX linear power supply but didn't like it - to be fair the 5V output isn't meant to be the greatest. Sbooster is the winner out of the power supplies I've tried.
Some battery packs are better than others I will say. Much depends on the electronics inside. I also use one for my rpi and for both my chromecasts
I totally agree. It took me a while to settle on the RaviPower one that I've used for quite some time in preference to the iFi. I can't say the Ravi is the best out there, just the best of the ones I tried. The Sbooster is very good though (even better) and it doesn't need recharging. BTW I using an Allo DigiOne on an RPi3.
Battery is still a good and cost effective option.
Also using a modded 34/306 (Dada) to KEF LS50 speakers sourced from an Allo Kali + Piano2.1 and a linear PSU. I also use a couple of Sabre based DAC's running on Pi2's. Comparatively, IMHO, I find both to sound very good but the Allo re-clocked dual mono setup has the edge because it seems have more "space" to it. It is currently my main DAC and music source (using Spotify premium).
I'm Mel.
