Results 1 to 10 of 10
Thread: FS: glasshouse passive Pre
    Default FS: glasshouse passive Pre
    Proper clear out on eggs firmly in one basket...
    Glasshouse passive Pre with the following spec (as passed to me the previous owner)
    Tantalum metal film resistors/23 Seiden switch/Audio Note silver RCA sockets/Silver Charcroft Z-Foil lead resistor upgrade
    2 input model, the input selector on the front is not wired up-the toggle switch on the back, bottom left is the switch between the 2 inputs.
    £150
    I'm Spartacus.
    If this has two outputs I'd be interested
    Cheers, Jeff
    It does have two inputs Spartacus as per the description switched via a toggle
    I'm Spartacus.
    How many outputs?
    Cheers, Jeff
    Ahhh...sorry. I'll check when I get home.
    I'm inthescottishmafia.
    Should have two outputs if all the socket holes have been used. Easy to add another pair if not.
    Hunter S Thompson
    Photo of the rear
    Not been wired but easy to do.
    Hunter S Thompson
    I'm Paul.
    Hi can you tell me if this is sold....
    thanks
    Klimax DS/3,Lp12,Keel,Aro,Radikal/1,Kandid & Tron Seven (Ultimate) Klimax Kontrol/1,Solos/1 & Akurate 242's (mark 3)
    Hi, sorry, yes this is sold. Apologies that the thread hasn't been updated.
