Page 24 of 47 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 463
Thread: The vinyl illusion ?
  1. #231
    got both of you
    Default And there I was
    And there I was supporting you and you quibble over a 'typo'.
    was only good fun.... ive regularly been called worse.
    No problem "Stuth".
    No problem "Stuth".
    cheers harry
    Looks like this thread has run its course.
    I'm Alex.
    Quote Originally Posted by paulf-2007 View Post
    Not all drum kits sound the same, my preference would be Ludwig. Even two drum kits of the same make won't sound the same when the drummer tunes his skins to his own liking.
    All you know is how you like a drum kit to sound.
    Right. Even the same drum kit played by the same drummer won't sound the same depending on what the drummer had for lunch that day.
    Alex.
  8. #238
    Yeah, beanz means more 'bass'...
  9. #239
    I'm Dennis.
    There remains the fundamental contradiction between seeking objectivity with a system, and seeking a sound which is pleasurable by avoiding very revealing components. Often very good components may serve to reveal that others are poor.
    This of course produces discomfort in the listener who may resort to many strategies to alleviate this discomfort, one of which may be to replace the revealing bit with another one which is not so much so, and think of this as synergy.
    The positive approach is to search for other equipment which the revealing bit shows is a better performer.
  10. #240
    Indeed. The key point is to avoid simply 'papering over the cracks', and instead FIX the CRACKS.
    Or, put another way... Avoid applying a 'bandage' to a problem, and instead FIX THE PROBLEM itself... In effect, always address the SOURCE of the problem, directly (if possible), not merely the symptoms.
    Any other approach, quite simply, will NEVER CURE the problem!
