I purchased one of these cables from Amazon , AmazonBasics USB 2.0 A-Male to B-Male Cable
https://www.amazon.co.uk/AmazonBasic...dp/B00BCWALHM/
I'm Allen.
Should work fine with that
hmmm.. 16 feet is very long... In the DAC manual it states to use very short lengths... could that be the problem ? If you have a printer connected via USB, chances are, you may already have a shorter version of this type of cable...
Recommendations:
- The recommended connection to USB for best sound is with a direct USB connector i.e no USB cable or very short USB cable. You will find these connectors, in the UKhere & in the UShere. You may prefer a swivel type adapter for better ergonomics but these have not been tested for sonics yet. You will also need a commonly found USB A male to A female adapter which will give some more distance between the PC & DAC32 for interconnect cable connection & also to make the DAC32 orientate the right way up, otherwise it would be upside down.
- Kernel Streaming (KS) seems to handle computer memory better than Wasapi?
Should still work without a repeater. I use a 10 metre one and its ok
I'm John.
OK, hope I can help?
I believe your problem might be that you are leaving the DAC turned on while charging (blue light is on, you say) - this is not actually letting the batteries reach their full charge
Turn it off while charging overnight & see if all is good tomorrow?
You should really read the user guide - all the info needed is there, I hope?
I'm Allen.
I'm John.
You have a Ciunas DAC with silver push button switch which lights blue when pushed in, right? Is it pushed in our out?
You are charging from a USB port, right?
If the above is correct & the blue LED is shining when charger is plugged in, then there is a problem with the unit. One way of testing is to open the case & measure the battery voltage.
I'm Allen.
You have a Ciunas DAC with silver push button switch which lights blue when pushed in, right? YES Is it pushed in our out? out I get a bright blue light , In i get a dull blue light
You are charging from a USB port, right? YES
If the above is correct & the blue LED is shining when charger is plugged in, then there is a problem with the unit. One way of testing is to open the case & measure the battery voltage. Not keen on opening , may need to send it back then
I'm John.
Ok, I believe it is faulty, then.
