Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
Thread: Help Help Help etc
  1. #21
    I'm Allen.
    Toslink cable with Mac adapter
    Summat like this https://www.amazon.co.uk/Ex-Pro-TosL.../dp/B004IUJPP4
    Any idea what adaptor ?
  2. #22
    I'm Allen.
    Work time now until tomorrow
  3. #23
    I can clean fluff from a stylus
    I believe it when I see it
  4. #24
    I'm AMusicFanNotAnAudiophile.
    The adapter is already incorporated in the one I linked to.
    Chris
    Common sense isn't anymore!
  5. #25
    I'm John.
    i may be wrong but aren't jk ciunas usb only?
  6. #26
    Quote Originally Posted by kenworthy100 View Post
    That'll teach me to pay proper attention
    You're on your own, Al.
    Chris
  7. #27
    I'm inactive.
    No need buy buy anything if you are already connected by USB to your DAC.
    Just go to 'System Preferences' in the Apple menu (top left) and click on 'Sound' - then check the output is set to USB.
    If you want get all fancy you can set the output bitrate in 'Audio Midi' set up (in the 'Utilities' folder under Applications)
    If your DAC is up to it you will get a better result with USB than using the toslink output in my experience - I never go near it now.
  8. #28
    I'm rupert.
    If it is a USB DAC it should work fine with a USB cable.. and it should show up under the little loudspeaker in the top Finder bar. No need for the Midi settings. It should just work. Btw. I don't see a optical out on this DAC.
    All the best
    https://sites.google.com/site/jkciunas/ciunas-dac
    edit.. from the manual
    Try a 5V PS to charge it instead of USB hub & see how that goes before trying to figure out how to adjust the USB port behaviour on a Mac.
  9. #29
    I'm inactive.
    Quote Originally Posted by r100 View Post
    ... it should show up under the little loudspeaker in the top Finder bar.
    Indeed ... I always forget that (have mine switched off)
  10. #30
    I'm Allen.
    Headphone Output!
    It has a 3.5mm jack , I thought headphones were not digital and the headphones are analogue ?
