Originally Posted by
Macca
It might make a small difference, but it is mainly low bass that travels through walls and that tends to be omnidirectional. If they are not complaining then I wouldn't worry about it.
Yep, my neighbours only hear bass... I can crank up non-bassy music & they don't hear a thing, but get a bit of reggae or drum 'n bass on, well... :P
If you wanted to really make a difference, you should decouple your speakers from the floor i.e. don't use spikes.
