Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Enlarging the spindle hole in an LP?
  1. #21
    I'm Russell.
    Personally I would use a small rat tail file. I've got a few I've used for modeling and instrument work, but a round file from a mini file set works so easily, and is super cheap. Just stroke the file in curved stokes, working your way around, so that it's even as you go. I have also taken a thin pencil and wrapped stick on sand paper to it, that will also clean and enlarge a hole with a bit of control.
  2. #22
    I'm stuart.
    Quote Originally Posted by Qwin View Post
    It needs to be a bit bigger, my spindle measures 7.3 and you would be at the very top of the taper. The spindle needs a small amount if clearance or it will still be a very tight fit. Hence me suggesting 6.5mm but a 7mm will also work(narrow end dimension), you will be working at the narrow end of the taper with that. Mine is 7mm and the reamer only goes in about 15mm when the hole is the right size. To be honest some of the cheaper reamers with a faster taper would be good enough for the job, something like this:
    http://www.ebay.co.uk/itm/3-12MM-REA...cAAOSwMedZcT93
    That looks like just the thing I need, cheers.
  3. #23
    I'm Nathan.
    A Bic pen works wonders for me!
