Results 11 to 20 of 23
Thread: Enlarging the spindle hole in an LP?
    I'm Ken.
    A tapered reamer should do it, coupled with restraint.
    That, and making sure that the material you ream falls away from the record
    Does the job extremely well.
    I purchased a tapered reamer (7 to 9mm) off the Bay for just this purpose. It has only been used for this task, so is very sharp and has to be used gently, so as not to remove too much material. A couple of light back and forth rotations is usually enough.
    I'm stuart.
    Quote Originally Posted by Qwin View Post
    Hi Ken, Do you have a link to the item you bought?
    I'm jamie.
    I use a 7.3mm drill bit, but I have been known to use the pointed end of a potato peeler which works just as well.
    i use the proper tool for the job, 1 half of a pair of scissors
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Ken.
    Quote Originally Posted by killie99 View Post
    I bought it about 3 years ago, along with a ratchet "T" holder, so I don't have a link.
    This is similar to what I have:
    Using multi flute slow taper reamer keeps the hole round and centred and as you can see, cheap as chips.
    EDIT: I've taken the link out, item was too large, you need a 1:50 taper reamer with diameter of around 6.5mm. I think a 7mm is the size, I will see if I can find one.
    Its a 6.5mm 1:50 taper that is needed, which goes from 6.4mm dia to 8.78mm dia. Can't see that size for sale at the moment, a 6mm will do as it goes up to 8mm max. It will be 110/120mm long approx. They usually quote the max dia and nominal size at the small end which it will fit into.
    Yep, that will work as well.
    I'm jamie.
    i expect there's some audiophile tool out there thats grossly inflated in price as well !
    My System
    John Wood KT88 Amp.
    It's called a pencil
    Yes - there's this: http://www.forums.stevehoffman.tv/th...-drill.347485/
    Yours for a mere $50.
    I'm Kevin.
    This 6mm one should be perfect: http://www.ebay.fr/itm/3mm-to-20mm-S...rmJd1iQDGr1FGw as it (apparently) goes up to 7.3mm.
    Kevin
    I'm Ken.
    It needs to be a bit bigger, my spindle measures 7.3 and you would be at the very top of the taper. The spindle needs a small amount if clearance or it will still be a very tight fit. Hence me suggesting 6.5mm but a 7mm will also work(narrow end dimension), you will be working at the narrow end of the taper with that. Mine is 7mm and the reamer only goes in about 15mm when the hole is the right size. To be honest some of the cheaper reamers with a faster taper would be good enough for the job, something like this:
    http://www.ebay.co.uk/itm/3-12MM-REA...cAAOSwMedZcT93
