Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Enlarging the spindle hole in an LP?
    I'm Kevin.
    Default Enlarging the spindle hole in an LP?
    I have a copy of Massive Attack's 100th Window where the spindle hole is really too small to even attempt to fit it.
    What is a sensible way of enlarging it? I can pick up 7.3mm drill bits for a couple of quid, and an adjustable reamer for about a tenner.
    Any thoughts/experience that people would like to share?
    Kevin
    I'm stuart.
    I've noticed this more and more. My box set of Bowie's 'Who can I be now?' needed every hole enlarged (ohhhh matron ). If it's just a tiny bit tight I use the outside of a BIC pen (the old style yellow ones) and gently ream the hole. but an adjustable reamer or correct size drill would do the job.
    I'm Brian.
    Drill bit used by hand mate .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    I'm AMusicFanNotAnAudiophile.
    A tapered reamer should do it, coupled with restraint.
    That, and making sure that the material you ream falls away from the record
    Chris
    Common sense isn't anymore!
    I'm Deleted.
    I just use the tapered wooden handle of a paintbrush I have.
    Account Deleted
    That's what I do.
    I'm Anto.
    I am reminded of a user on another forum who put his Knosti in his cordless drill to spin the discs dry!!
    You could drill them out
    Done this a few times, carefully, with a penknife blade, turned slowly and carefully, checked and if necessary turned again until hole fits spindle smoothly
    Mike
    I'm Kevin.
    I have just ordered a couple of 7.3 mm drill bits. I may take the .004" off then, but will measure them before I use them to make sure they are not too big.
    Kevin
    I use a 7.3mm drill bit, but I have been known to use the pointed end of a potato peeler which works just as well.
