Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Is Re-Veneering Speakers Beyond The Keen Amateur?
    Default Is Re-Veneering Speakers Beyond The Keen Amateur?
    Hi
    I was thinking that I must do a project to get some more Royd Minstrel cabinets and put a lovely real wood veneer on them. I think the key is spare cabinets to see if it works out before transferring drivers and cross overs
    I would also want to do some Conistons (maybe too hard because of the foam lined ports and internal construction) and some Celestions I have. Im sick of black for one reason and I don't buy black speakers now or that fake wood grain look vinyl wrap.
    I feel it's a job Im going to bodge at some point because even getting a straight edge with a veneer scraper looks like a practised skill. Of course there are driver cut outs and port holes making the job much harder to finish neatly
    Should I get a quote from a cabinet maker? Someone made my dad a lovely unit and Im sure veneering speaker cabinets would be fairly easy for them to do properly. Ive got to think of staining and a decent finish which is a minefield to me
    It can't be rocket science but I'm worried about spending on decent veneer and bodging it up as Im a prefectionist with ideas well beyond my station.
    It's just something I fancy having done although with a quote it may not be cost effective
    Any thoughts please as I mull it over?
    Cheers
    Martin
    I'm Peter.
    Martin,
    It's not beyond your experience if you get the correct veneer!!!
    In fact, it's pretty easy with a few tools.
    See below, a couple of speakers veneered to perfection, me thinks.
    Any advice, no problems.
    Peter
    Ah yes thats very nice thanks.
    Trouble is Ive been watching the videos and there is a lot to gear up with including the choice of veneers. There is a lot to go wrong and even the proper edge cutting tools add up for a job I wont be doing more than a couple of times.
    Its choosing the real oak and waxing it or whatever....it just seems a job for a place geared up with all the stock and equipment. I doubt I would be able to do all of it correctly as I can get so far then bodge it in a crucial stage of finishing
    I have just emailed Audinni for a ballpark figure. They look an excellent organisation but I fear I am in Spendor land regarding possible prices.
    Its interesting as there are people that will do it. Im just deciding whether it is cost effective.
    All the best
    Martin
    I'm matt.
    A guy I spoke to at a bake-off said he tried to veneer his speakers but made a right mess of it. Obviously, on forums you're only going to hear about the ones who didn't mess it up. If you're not sure, it may be better to get a professional to do it.
    I used veneer on my current diy speakers to form a curve but even though I used tons of pva glue on the veneer and mdf, I still had parts that didn't stick properly. I used a damp towel and a hot iron to flatten most of the bumps but had to cut some out and fill. Luckily the veneer was never going to be seen.
    'Obviously, on forums you're only going to hear about the ones who didn't mess it up.'
    Not necessarily!
    http://theartofsound.net/forum/showt...ight=veneering
    veneering curves can be tricky. not tried myself but a guy i used to know, who was a pro used to soften it first the clamp it til dry
    I'm paul.
    I made a right mess of a pair of speakers then made a half decent job on my round turntable plinth. I would say get a professional to do the speakers as they are on view and veneer is not cheap.
    Never had a problem veneering speakers (or anything else), but I'm a handy sort of guy. I guess it can be messed up if you try hard enough .
    I certainly would not use PVA glue to bond veneer. I always use Thixofix and rub the veneer down using a small softwood block. Some of my speakers are still around with good veneer thirty or more years after I made them. I've made over fifty pairs by the way.
    I'm matt.
    Quote Originally Posted by RMutt View Post
    Not necessarily!
    You're obviously one of the few honest people out there
    I'm matt.
    It's Youtubes fault, not mine
    To be fair, I couldn't use contact adhesive because I needed to be able to adjust the veneer to form the curve. After I formed the curve and then filled the inside with fibreglass to strengthen It.
