Results 1 to 7 of 7
Thread: Little Dot valve amp.
    I'm nigel.
    Default Little Dot valve amp.
    I recently took my first step into the world of tubes with a Little Dot headphone/pre amp from amazon.
    a very highly regarded piece of kit...I am currently using to great effect purely as a pre.
    it has only one input but this presents no problems as all my sources are routed through my DAC... a SMSL sanscrit, also cheaply purchased from amazon.
    I was wondering if anyone has experience of this amp and can recommend a decent tube upgrade, the supplied Chinese valves are reputed to be quite poor.
    I must add that even on its current tubes the sound is (for the money) stunning.
    NIGE.
    Which model is it I've got a mk3 and used to have a mk4
    I have a mk 1 and it's bloody good.
    I'm nigel.
    its the Little Dot MK 2.
    driver tube 6J1
    power tube 6N6
    I have NO IDEA what the above tube designations mean !!!
    I'm Tony.
    Watford Valves do sets they have tested specifically for the Little Dot range.
    I recently bought the Mullard/Novosibirsk set for my Mk2 and am really pleased.
    2 x M8100/CV4010/EF95 Mullard
    2 x 6H6PI/6H6N Novosibirsk “NEVZ-Soyuz"
    https://watfordvalves.com/products.asp?ID=35&man=347
    Tony
    I'm steve.
    Mullard ecc182 in place of 6n6 and as Tony says ef95 for the other
    Ecc182 are fairly rare but should not too expensive
    Old mullards should show the stock valves a clean pair of heels
    Pm me if you can't get hold of any
    Cheers
    Steve
    collector and DIY user of old british triode valves
    Open baffles / single ended diy px4 and px25 valve amps
    I'm nigel.
    thanks all.
    I've ordered the set recommended by tony from watfords.....gunna have the "where's the postman" tingle for a few days now
    NIGE.
