Originally Posted by
montesquieu
I used one of these with an LP12 and later on a Rock, I thought it was a significant upgrade over the Ittok and far ahead over an RB300. It's a really superb arm with the likes of a ZXY or a Lyra, you don't want anything too low compliance but otherwise relatively easy to match up.
BTW I run a TD124 after being round the houses (LP12 with all the upgrades, Rock Reference, Voyd 3 motor, Garrard 401, assorted Lencos, JVC DD and several others) and I'd say once you get the TD124 sorted it stays put far better than an LP12 which needs the suspension regularly kept on top of.
Anyway I'm a big fan of the Alphason, it's a seriously hard act to follow if it's been sensitively matched for cartridge and set up properly.
