Results 1 to 4 of 4
Thread: wanted tube adapter
    I'm gerald.
    Default wanted tube adapter
    Looking for 3x adapter to take a ecc83 fitting to a 6n2p fitting tube as a friend of mine has a load of 6n2p tube that I can try out .
    The adapters are likely to cost more than the tubes. If the heater circuit is 6.3V its an easy soldering job to reconfigure the socket wiring (disconnect bridge from pin 4 to 5 (but leave the wire attached to whichever pin - 4 or 5 that it arrives at) , disconnect wire from pin 9 and reconnect it to 4 or 5 - whichever does not now have a wire attached.
    You can install a simple switch to achieve this to allow fairly rapid swapping.
    If the heater is 12.6V the Russian valves can't be used.
    I'm Graham.
    Analogue. Basis signature 2200,Basis Vector 4.Koetsu Red,Koetsu SUT,NVO SPA 11.
    Digital. Denon 2900,Jolida FX 11
    Amp. Pathos Logos,Minidsp dirac 22A.
    Speakers. Amphion Xenon.
    Airlink CBS 2000 bps
    I think that James is right. I understand that the Russian valves you want to use are part of the ECC88 family and therefore work on different voltage.
    I would not risk it as there are myriad 83/family valves around for you to play with. Many at cheap prices
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
