Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: New turntable dilemma - which one to choose between 2.
    I'm Mark.
    Default New turntable dilemma - which one to choose between 2.
    I have decided to add a turn table to my system ( and break out the stored vinyl ), and have narrowed it down to 2 setups,
    both are used, and are the total same cost.
    1. Michell Gyro SE, SME 309, Denon DL-110, Whest two phono stage.
    2. Kuzma Stabi S, Stogi S, Linn K18, Lejonklou Gaio phono stage.
    Any comments, things to look out for, etc welcome.
    Mark
    I'm AMusicFanNotAnAudiophile.
    Why the cartridge choices?
    Chris
    Common sense isn't anymore!
    It won't matter which one, because within weeks you'll be upgrading anyway, it's the nature of the beast and it can't be killed
    Both are excellent turntables I would go for the one you like the look of best and enjoy.
    Just
    had a whest 2...i wouldnt again. but the gyro is a good deck. dl110 is decent, but can be improved and sold easily enough as could the whest if you dont like it. Think its more a case of which tt floats your boat
    I'm Mark.
    basically both are in for free
    I'm Mark.
    Grant, looks wise I love the Gyro and the sme arm, very visual, but i also love the simple uncluttered look of the Kuzma.
    What was it with the Whest 2 you didnt like ?.
    I'm Mark.
    Just
    i Like the look of the Stabli too.. solid oak and a good psu. arm might be an issue for me. I like a detachable headshell as it makes life a lot more simple. sme arms are very good bits of kit
    I'm Simon.
    Stogi S is the nicest arm I've ever owned and I've owned rather a lot so I'd being going for the second set up.
    I'm Bob.
    Gyro + SME = Choice pairing.
    Both well engineered and likely to hold their price if you decide that ultimately they're not for you. You don't see too many advertised, folk tend to hang on to them.
    And both will work well with other combo's if you decide to split. The 309 is capable of taking a better cartridge if your experience takes you that way.
    Visually the Kuzma leaves me cold. (but, I know, we don't listen with our eyes).
    Source: Orbe SE / SME IV / Cadenza Bronze
    Source: WD NAS / Cyrus Stream X2 / Chord DAVE
    Source: Oppo UDP-205 (CD/DVD-A/SACD)
    Amplification: Icon Audio PS 3 Sig Phono + Audio Research LS27 + Musical Fidelity A5cr Power Amp
    Loudspeakers: ProAc Response D28
    Cables/stands: Mark Grant G1500HD + Linn K20 + Cat 5e
    Other bits: Okki Nokki keeping things clean
