Looking to connect on of the latest Macbook pro's which only has the USB 'C' type connectors.
Want to connect this to my Rega DAC R's USB 'B' input.
Can anyone recommend a suitable cable/supplier?
Thanks
I'm Geoffrey.
Thanks
Here you go mate: https://www.amazon.co.uk/Cable-Matte...dp/B00UUBRX0Y/
