Originally Posted by
DSJR
I got my hand slapped when trying to access this link. To make sure I opened the page individually, logged in and downloaded the manual...
Looks to be a very sensible design to me with a stout arm tube, unipivot and hopefully a good cartridge - NOTE THE 68K LOADING REQUIREMENT!!!!!!! The usual 47K loading may cause dullness.
I haven't a clue about stylus availabilty and there doesn't appear to be a bias corrector, but if it needs re-wiring (almost certainly) the service manual is downloadable from VE and Johnie at Audio Origami should be able to sort it if you so desire.
Fortunately I can fully adjust the loading with resistors on my phono stage. It has preset for 47 100 and 1000 K ohm as standars, but infinite combination of settings is available by soldering resistors to the type of connector (RCA or XLR) that is not being used and plugging these connectors into the phono stage.
My Gear
Source components:
Garrard 401 in a solid birch plywood plinth / Trans-Fi Terminator T3Pro / ESCo modified Denon DL-103
Pioneer TX-9800 tuner
Amplification:
Art Audio Diavolo and Conductor, Pair of XTZ Sub Amp 1's, Nick G 'Dual Phono' phono stage
Loudspeakers:
Bastanis Mandala Atlas with 15" sealed woofers
Cables:
Analysis Plus: Big Silver Oval speaker cables and Silver Oval-in interconnects, Mark Grant DSP 2.5 Dual Screened power cables
Record cleaning
Nitty Gritty 1.5Fi MK II
