Results 1 to 2 of 2
Thread: Platine Verdier armblock total refurb and fitting of Jelco Ammonite Uprated armbase
    Default Platine Verdier armblock total refurb and fitting of Jelco Ammonite Uprated armbase
    This Platine Verdier block needed to be modded to fit the Ammonite uprated Jelco armbase.
    It had seen quite a bit of action with various armbases..
    Here it is as was
    Here it is refurbed and lacquered in gloss black with armbase fitted ready to go.
    Spacer in aluminium, locating pin in stainless steel and collate in birch plywood.
