I can do them much cheaper if you only have 1 leg on each stand!
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
finally got round to sending it off to be re-tiped...the anticipation begins!
My System
John Wood KT88 Amp.
the report back with current prices,
not bad for 50 yr old stylus that imo betters a 2m black or zyx r-100
1. Decca C4E cartridge, serial no.11305.
Stylus 20% worn output and separation good.
Options:-
Clean and test..............................£40.00
Install extended contact stylus..£255.00
Install Paratrace stylus..............£300.00
My System
John Wood KT88 Amp.
what do you mean sell everything else? lol
my only concern with the paratrace is azimuth has to be spot on,as you know we cant do that with the alphason so it would have to be done with paper shims or the like.
having said that though i did do that with the 2m black and it wasn't too much of a ball ache.
i asked john wright to fit what he thinks best and that was the extended line contact tip.
My System
John Wood KT88 Amp.
Well, yes it's the only downside of the Alphason.
You're not gonna go wrong either way to be fair. I'll be watching for your review of the Decca.
well its back from john wrights and looking mighty fine!
from this,
to this
i shall be fitting it after ive had a kip
My System
John Wood KT88 Amp.
I'm waiting for the review!!
