Page 17 of 20 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 195
Thread: Decca C4E cartridge
  1. #161
    Something wrong there. The Mk.IV Deccas should have a somewhat more full bodied sound than the Londons, including the Golds. I'm wondering if the coils were set up correctly.
  2. #162
    I'm Oliver.
    Quote Originally Posted by paulf-2007 View Post
    Well I bought Jamie's Decca and after setting it up in my stax arm, which was fine with a super gold and some putty, I had a disappointing afternoon. Did a basic set up and had it tracking at 1.5grams, very thin and slightly harsh sound with no bass and worse still, was vocals were difficult to hear and fading as the track played. The whole sound was like an echo. I gave up and put the Shure ultra back and all was wonderful. Going to need some help. I met a guy yesterday who is very experienced with decca's and he suggested blue tak blobs until the best sound was found, then weigh it and replace with lead. Well I couldn't even start to think about blue tak as their wasn't anywhere to start. Cart and headshell weighs just over 25 grams, I have an extra counterweight that I fitted but there is room for adjustment if the headshell needs more mass. Any thoughts?
    What setting is your phonostage on? It's either the wrong setting or you are out of phase. I had the four pin connector on the Gold and it sounded just like you say. I swapped to the three pin and only connected the red white and green. That fixed it. Never got the bass I wanted though hence me moving it on.
    Analogue: Technics SP10 MK2 > Phonomac AT-1010 tonearm > Ortofon Kontrapunkt b > Wizard Jfet MC Valve Phonostage (Telefunken Valves)
    Digital: Firebottle modded Xiang Sheng DAC (Telefunken Valve)
    Amplification: Slagle AVC Passive Preamp & Firebottle Monoblocks (Telefunken Valves)
    Cables: Fisual S-Flex Speaker Cable & SPOTFIRE IC Cables Throughout
    Speakers: Pioneer CS-77A
  3. #163
    I'm jamie.
    remember this cartridge is nearly double what a mk 5 weighs,i got it to sound very good using my 11g alphason and 16g zeta,both i used with fluid damping,have you checked that you tonearm is compatible?
    also when you picked it up you mentioned you were giving it too your friend to try first,what tonearm did he use?
    My System/ Yamaha NS1000M speakers ,Pioneer PLC-590 turntable,Pioneer PA-5000,Alphason HR-100S-MCS,Zeta tonearms,Denon 103SA Cartridge's,Denon HA-500 Head Amp, John Wood KT88 Valve Amp,Sony 700ES Amp,Sony X555ES CD Player, Nakamichi ca5 pre amp ,
  4. #164
    I'm jamie.
    that's exactly how it sounded when i compared it to olivers london gold,the c4e was up a notch.
    theres nothing wrong with the coils geoff,it was working fine prior to being sold.
  5. #165
    I'm jamie.
    also its calibrated to be run at 1.8 grams.
  6. #166
    I'm paul.
    My mate didn't get around to trying it. I'm sure there's nothing wrong with it Jamie, it's only been in the box in my pocket and at my mates and he hasn't even looked at it.
    Sony STR 6055 Denon DP80 Stax UA-70 Shure Ultra 500 Zu omen
    Office system, DIY CSS fullrange speakers with aurum cantus G2 ribbons Najda dsp as dac Akai AM-U02 Jvc QL-A51 direct drive turntable
    SAE1000LT leema sub. JVC Z4S cart is in the house
    Garage system another Sony receiver, cassette deck and full range drivers in free air
  7. #167
    I'm paul.
    Jamie, did you use the terminal with the green sleeve on. I used it as ground for the left channel.
  8. #168
    Yeah. It's worth experimenting with neg connections and checking phase.
  9. #169
    I'm jamie.
    no!!!! thats for testing only,thats why it has a green sleeve on it,you just use 1 earth tag. thats your problem right there paul.
  10. #170
    I'm Oliver.
    I said this 7 posts back.
