Originally Posted by
meBob
My room is 12x12 ft and with painted walls (no wallpaper), it has floor to ceiling heavy curtains with a wood floor, it's probably not ideal with a bit of echo when the volume is up. I have a large rug to put down, that should sort the floor out, but the wall facing the speakers is big and bare, a bit like a sounding board.
"Step 2 is an ampifier capable of driving the speakers properly."
If not I will consider the Vinyl / CD route.
But vinyl is a two edge sword, not only does it sound better (IMHO) but it also deadens the room if you have a shelf full of the stuff
The room is similar size to mine except I have carpet down.
In a room that size I would have thought either of those amplifers had enough watts to drive any speaker unless you like PA sound levels. (I rarely listen above 85db)
Andy
Analogue
401 / PU7 / AT33ev
Digital
Innuos Zen Mini Mk 3
Topping D50s
Caiman Seg & Dorado
Cambridge CXC
Amps
Tron Seven Linestage
Speakers
Tannoy GRF Memory.
Tannoy ST100.
