Results 11 to 20 of 22
Thread: RCA Help!
    Agree it doesn't look 'quite right', but if the plugs are pushed home reasonably well, and not too much strain is being put on the sockets, I wouldn't worry.
    I'm Shane.
    Thanks chaps.
    S.
    I'm Neil.
    Stick a thin piece of card in between the plugs so they aren't physically touching.
    I'm AMusicFanNotAnAudiophile.
    Why?
    Chris
    Common sense isn't anymore!
    I'm inthescottishmafia.
    Would make no difference. The grounds of the RCA sockets will be connected inside the chassis anyway.
    Hunter S Thompson
    I'm Jez.
    There are various ways the grounds could be connected internally so it would be a good idea, if OCD about these things, to use that piece of thin cardboard... It will probably be fine though.
    Just cut of the old plugs and solder on some new thinner ones would seem the obvious solution.... The insulation may have to be cut back to allow the entry of such thick cable but some heat shrink sleeving should make it look neat again
    ive seen some that were not directly connected. Not usual tho
    I'm Phil.
    I have used this between close fitting rca in past . still use it where interconnects touch sometimes
    http://www.tnt-audio.com/accessories/ers_cloth_e.html
    agree with comments about adaptors , better to find a thinner profile plug . I would be asking advice from paul coupe at rfc components
    Eric Bibb
    Personally, if the sockets have common negative as is usual (but not exclusively so), I'd not worry about the plugs touching.
    I'm Edward.
    Why not simply loosen one of the metal protectors on the lead and move it slightly away?
