Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: RCA Help!
    I'm Shane.
    Default RCA Help!
    My stereo interconnect cable are terminated with Audio Note AN-P RCA plugs.
    The plugs are chunky, and fairly wide. On my equipment, fitting the second plug is a tight squeeze
    Would it be possible to buy some type of RCA adaptors, that can also space things out a little?
    S.
    I'm inthescottishmafia.
    Do they actually fit and work Shane?
    If so, what is your concern?
    Hunter S Thompson
    Photo?
    http://www.ebay.com/itm/like/2515378...016&rmvSB=true
    something like this... you might find a better set somewhere tho.
    I'm Shane.
    Photo?
    Will take a pic tomorrow, Geoff.
    S.
    I'm Hugh.
    An RCA plug is should be designed to fit an RCA socket. If it doesn't, either the plug or the socket are 'not fit for purpose'.
    Quote Originally Posted by narabdela View Post
    It's not the plug and socket per se that Shane is having a problem with - it's the narrow (close) spacing of the sockets, causing the two wide-bodied plugs not to mate securely.
    I figured that might be the problem. That's why I asked for a photo. If that is the case, changing the plugs might be best.
    I'm Shane.
    I can see the problem Shane.
    The photos highlight another issue. It's a thick cable and will require plugs with a broad entry, any of which may produce the same result.
    Adding some kind of adaptor to avoid the crowding at the sockets rather defeats the point of having a decent cable.
    I guess you could speak to Audio Note though. They may be able to help.
