hmmm
hmmm
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
I'm Shane.
And following the rush ( reminds me of the Neil Young song ) the ability of diode bridges to handle such capacitance is a major concern. The old rule of thumb, that is still immently sensible is 1000uf for every amp of current drawn. The LT4320 using 4x N channel hexfets at 50 amps each, might provide ability for such high capacitance, but are then limited by Rds on of the mosfet and voltage can be no higher than 70v.
I don't want to bastardise - but it's quite old and I'm sure some of the components must be out of spec - though I don't know. It sounds extremely good. In fact I was planning on a post about it compared to my Cary monsters.
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
I deliberately used that word as the initial post suggested more to me than a simple check up and more a modification. It is possible that components may be off spec and it would be worth getting them measured. If all still in spec and no bits known to fail suddenly then I would leave alone. Changing components out even if same values can change the sound unless they are identical parts but the problem will be that manufacturing changes to those parts might alter the sound.
I know some folks aren't precious about designers work and as long as they get a perceived improvement will happily alter a classic design but from a collectors point of view, and yours and any amp designed by that legendary designer fall under that heading then altering them will kill the collectors value, and ruin what that designer designed that amp to be.
Put it simply a Lectron amp or yours unaltered I would buy, but a messed with one, nope wouldn't touch it with a barge pole. That's me and others mileage will vary. You pays your money and makes your choice.
Regards Neil
I would first off' just replace the power supply caps for decent quality new ones, and posibly upgrade the diodes, or bridge rectifiers for better ones, and see how much it changes things first before going too drastic, you may end up turning something you currently like, into something somewhat diffrent to what you remember!
Just my ramblings.
A...
Nikola Tesla
www.tubedistinctions.co.uk
Matthew 5:10
Thanks guys. I don't want to change the design so sorry if my initial post suggested otherwise. I do however need to investigate an issue and thought it might be a good chance to pimp up some components
The issue I have is that with it connected there is a grounding issue - touching the fingerlift causes a hum. If I float the ground on the preamp it goes away. Not sure if this is a design flaw or if something is wrong. It's not an issue with other amps.
Also the red neon rocker switch for power doesn't completely go out - it's always on albeit at a low level.
Saying this it sounds extremely good - in some areas beating my Cary 805c monsters.
Sent from my Aquaris X Pro using Tapatalk
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
