How come since my last Win10 update, Google Chrome continually crashes Win10...? Is this some cunning plan by Microsoft...?
I'm Shaun.
Do you mean crashes on Win10.
If not then perhaps it is a cunning plan by Google .......?
Full uninstall and reinstall of Chrome?
Sent via Tapatalk
That may work.
However, it's not uncommon for 'windows updates' to cock something up, which is then corrected in the next update. As updates are pretty regular, it may be worth waiting to see if the issue is remedied shortly.
Alternatively, if you like Chrome, there are several other browsers that are Chrome derived and are very similar to use. You could try one for the time being.
Possibly, but if it was a MS cock up there ought to have been widespread reports of it.
If the OP does not want to uninstall /install I would suggest clearing the Chrome Cache and/or creating a new Chrome profile.
But also try usual things like Safe Mode etc.
I have several instances here of win10 and Chrome and have not had any issues following the Creators (or subsequent) updates
Sent via Tapatalk
My Google chrome has recently begun to crash a lot and is also very sluggish,my Acer tablet has become a real pain in the arse use
In case you're using an antivirus or firewall software, ensure Chrome is trusted or permitted by these programs. You can also try temporarily disabling your antivirus or firewall to check whether this determines the issue.
if you have a logitech web cam, try disconnecting. or any other logitech equipment drivers.
if its android, then its likely a bad update which will no doubt get fixed
No trouble here with Google Chrome on Windows 10 and just as well, because I wouldn't know what to do if it did.
I'm Shaun.
The main problem is firing up Google Chrome as within a few seconds it crashes. After that Win 10 fails to operate correctly and a reboot is needed. Even Microsoft Edge won't run correctly after Chrome crashes. This has all happened since the last major update of Win 10. I have been checking and there are reports of this all over the net.
could be a problem with chrome, or a driver being used that isnt now working. as i said some logitech drivers have been found to cause this but there may be others
