Andy I assume they're broken, cracked. Simpler fixes may exist. Filler and cover plates etc.
Ate the on offswicth and the speed selector the same parts?
Nope, have a look at this.
I've sent the speed selector switch to Mark to see if he can produce a CADCAM file for me for 3D printing.
What about rumaging ebay for a similarly shaped vintage bakelite knob that can be filed to the required form?
I'm Deleted.
Andrew, your inbox is full. I've changed the cross to a slot 3mm x 5mm as per your sketch. If you send me an email address I will send the files, although it is unlikely you will be able to view them.
Account Deleted
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Any chance of getting a scrap turntable from ebay or elsewhere with the parts you need?
Dave
I'm Deleted.
I've already sent Andrew screen shots.
Account Deleted
