Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: LP12 and Naim Aro Armlift
    Something like this maybe?
    http://www.ebay.co.uk/itm/Yamamoto-S...cAAOSwNSxVB5OQ
    It looks as though it fixes via two screws from the top, but I'd be inclined to try mounting with thin double sided adhesive tape. I did this with my arm rest very successfully.
    This certainly looked the best idea from the various arm lifts around but having measured carefully it looks as if this device won't lower far enough down.
    Therefore there is a danger that the arm rest will foul the arm as it travels across
    Nothing is straightforward eh what!!!!
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
    I'm martin.
    Plan A then TPA Elevator I know it works as I've got one fitted.
    Found on the Analogue Seduction web site that the Q Up at £49.99 is supposed to work on a Linn.
    Martin
    Quote Originally Posted by martinjohn308 View Post
    Martin
    Thanks for the suggestion. I had looked at this as the site it could work on the LP12. However it would have to be tried as it may well bridge the gap between top plate and armboard so interfering with the suspension
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
