Results 1 to 10 of 20
Thread: Dirty contacts
    Default Dirty contacts
    I had some crackling / noise on a volume control the other day and used some contact cleaner to sort it. Not only did it remove the noise it seems to have improved detail and imaging.
    Is this possible or am I imaging it?
    In general can cleaning contacts significantly improve equipment / system performance, has anyone else noticed this?
    I'm Brian.
    Yes , I've experienced the same improvements as you James . I make a point of cleaning all the contacts , mains plugs and phono plugs , with Deoxit once a year and always reap the benefits with improved SQ . So no , you're not hearing things IMO
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    Where exactly did you apply the contact cleaner, Jim?
    Remember that volume pots sit directly in-line with the signal path (and at a critical point, too), so it's not surprising that improving integrity there has resulted in better SQ!
    I'm inthescottishmafia.
    The signal is going through the pot, so cleaning the contacts will make a difference to what you hear.
    Hunter S Thompson
    I applied the contact cleaner directly into the volume pots - they are fairly simple device on the Croft 25R and very accessible. I had heard some slight noise/crackles before i applied the cleaner but now nothing. However afterwards I noticed some more detail in the sound stage which had not been apparent before. Since posting this I have had a look round the net and found one HIFI journalist who had very similar results so maybe its definitely not me imaging it.
    I have now been through all my contact points with the cleaner and very pleased with the results. I used WD-40 Specialist fast drying Contact cleaner to do the job. Not particularly expensive and easy to apply with a long spray nozzle.
    Change of resistance
    Glad you are hearing this, Yes there are always losses with volume pots processing audio signals, as it is one
    surface grinding away on another with your audio signal the sandwich in the middle.
    Sadly no one except you and me wants to know about it. There is always an immediate rush to defend what is
    accepted, but not properly questioned, and you will quickly see comments reestablishing praise of pots,
    basically reasserting mediocrity- best to ignore them.
    This is why contact less optical methods creating a variable resistor by varying intensity of light is preferable. When done
    properly they are far superior, when done poorly though with cheap voltage regulators they are slightly better but fairly
    similar to pots.
    There are other methods too including fets used as variable resistors, transformers too, can also couple, so broadening your appreciation of attenuation methods, is very worthwhile.
    Cheers / Chris
    I'm mick.
    Get yourself a can of Servisol,much better than WD40,which is not an out and out contact cleaner.Servisol is a lot cheaper than Caig Deoxit,which is also recommended but I have never used .Maplins sell it so is easily obtainable Mick
    Nothin' I do don't seem to work ,it only seems to make matters worse!. Jagger/Richards
    If you read the post it is specialist WD-40 contact cleaner, not standard WD-40.
    I'm Adrian.
    Quote Originally Posted by Light Dependant Resistor View Post
    similar to pots.
    Cheers / Chris
    Totally agree - hence my love affair with the Truth linestage.
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
