Results 21 to 30 of 36
Thread: Tone arm cable trimming ?
  1. #21
    I'm jamie.
    tight arse,use the right tools for the job lol.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  2. #22
    I'm Allen.
    Its my birthday soon , you can treat me
  3. #23
    I'm jamie.
    ha ha,to be fair it is a tad expensive
    My System
    John Wood KT88 Amp.
  4. #24
    I'm Allen.
    Is that a no then ? tight arse
  5. #25
    I'm jamie.
    sweet as! you got me there
    My System
    John Wood KT88 Amp.
  6. #26
    As a rule, I have found insulation strippers pretty useless. I used to do a lot of soldering for a living many years ago and near enough every sleeve stripper that came my way was a waste of time. They either slip on the plastic/rubber or cut into the conductors as well as cutting the sleeve. By the time you've pissed about setting the cutting depth to a point where the cores won't get damaged, you might as have done the job by hand.
  7. #27
    But you do have a set in your tool arsenal don't you?
    A couple. They're crap!
  9. #29
    RothwellAudio Guest
    Quote Originally Posted by killie99 View Post
    If you are stripping a lot of fine wire these are a godsend
    http://www.ebay.co.uk/itm/C-K-330011...gAAOSw2gxYymOP
    The strippers linked to are very similar to ones I use for stripping wire-wrap wire. They're very good indeed, though pricey.
    At the other end of the price spectrum I have a pair of really cheap wire strippers which I bought from Maplin when I was a kid. Everyone laughs at them and says they look like rubbish but I find them very useful and still use them now. I can feel the insulation being cut and can usually judge how hard to squeeze to cut the insulation without damaging the conductors.
  10. #30
    I'm stuart.
    The ones I linked to are superb and will last a lifetime. Mine are adjustable from 0.25mm to 0.8mm and will not nick the copper stands and give a super clean cut on the insulation. They have saved me so much time over the years.
