I'm Oliver.
Or just buy the Dynavector P75 phono stage....Yes it will be another small box and wall wart.
Holbo TT-Nag 110-Croft phono/Innuos Zen MK2/LinnenberG Telemann DAC-Preamp/LinnenberG Allegro monoblocs/Duevel Venus/LinnenberG Maestro SE-Senn. 660S DH Labs cabling
Croft Series 7 amps, WLM La Scala, Naim Uniti1, Naim Nait XS3, Naim ND5XS2, Guru Junior
It should overload in the same way as your MC input! Either the head amp or the MM stage overloading with the 50mV or so output from the head amp... HOMC's are also usually designed to work into 47K and most head amps have an input loading of 100R - 1K unless modified for 47K loading.
The Headspace has a 10dB gain setting and it won't be overloaded, nor will the following MM stage. 10dB is a touch on the hot side for a 2.5mV cartridge but will be fine.
The Headspace also has adjustable input impedance and the 1500 ohm setting (the highest) should be ok too. I'm not exactly sure what the source impedance of the SAE cartridge is but I think a 1500 ohm load will be ok.
Do I get a SUT?
this may be of interest
http://theartofsound.net/forum/showt...t-MC-amplifier
"lack of passion is fatal"
I'm Richard.
Thanks Adam,
That certainly piqued my interest and ticked the 'something a bit out of the ordinary' box that I'm a sucker for ;-). I got in touch with David via Facebook and ordered one which arrived this morning. Only managed a quick listen before work having re-fitted my DV DV20X2L last night in anticipation of it arriving.
Initial impressions are 'Holy moley!'. I'll write something a bit more descriptive once I've had a couple of evenings to a. get the cartridge aligned properly and b. a few more hours to listen to it.
Thanks for the heads up..
Rich
I'm Richard.
Well, it has certainly done the trick. I've now got my DVX20L going through the 'Little Gate' into the MM stage of my NAD M12 pre and there is no more noise, no hiss and plenty of gain. I've never heard such low background noise from LP before and this little box just seems to let everything the cartridge is doing flow through with nothing added and nothing taken away. I've found myself digging through my collection for stuff I've not listened to in years and hearing it all as if anew. It has become a total addiction over the last few days. The music just flows and jumps out of the speakers at you with a MASSIVE soundstage, incredible agility in the bass and that natural sweet treble that only the best analogue is capable of. Bearing in mind that this ultimately replaces the Dynavector P-300 phono stage in my old L-300 which was no slouch, this is a great big step up.
If you've got a good MC and a good MM input on your amp, I can't recommend this enough. What you get out of it is well above what you'll pay for it.
If I have one minor little gripe it's getting at the batteries to take them out for charging. I made the mistake of leaving it switched on overnight the first night and by the evening of the next day it had run flat (although it's also possible that the batteries were not fully charged to begin with). The box has to be unscrewed to take the batteries out to charge them which is a little fiddly, but now that I've ordered a couple of spare 9V batteries of much higher capacity, I'll not have to sit without vinyl again for an evening and the replacements should last a lot longer between charges.
Rich
So that's a "no" then - you don't get a SUT.
Hi Richard, i'm pleased you like it.
your findings are exactly what I found. It's an incredible bargain for the price point and a total no brainer. As i said previously in a post, it gave my Hashimoto HM-7 SUT an extremely close race!
If you are finding the internal battery approach a pain, David also offers a unit with a PSU which of course illuminates the need for Battery.
I must say I have not had an issue with leaving it on after playing, and the batteries have lasted a long time... I reckon the bright blue light on the front may give you a clue it's still on
An uncomplicated, very good value for money approach that gives amazing vinyl playback results. Simple!
