Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 138
Thread: Goldring G99 - A Resto too far 8-<>
  1. #111
    Tonight's Update Pt XXXII - G99 is 99% finished!
    Here's a piccie of my 99 with the metal fascia nearly finished. The speed selector switch has been fixed into place, the strobe light window has been cut. All I need to do is get the on/off switches installed and install the decals and then it's complete. The plastic component of the top plate needs some more primer adding and then spraying, all of which can be done in a day. It's quite sad really in that the old girl is nearly finished. I guess this will give me more time to play around with the '75 and my Garrard 301. I will of course always be on the look out for restorations. So as always, stay tuned......
    PRE
  2. #112
    Great going Andy. Especially when one considers what you started from. Well done mate!
  3. #113
    Thanks, it's just been steady sway.
    PRE
  4. #114
    Will be interested in the comparison with your 301 (if that ever gets finished )
    I have only had a fleeting experience with a 301, but two 99s passed through my hands.
    I'm Keith.
    Quodos Andy. A job well done.
  6. #116
    I'm Brian.
    Aye well done Andy . You're getting rather good at this restoration stuff
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  7. #117
    Tonight's Update Pt XXXIII - A friend from Europe.
    Looks like we'll have some new on/off switches organised and to the correct sizes. This little venture came with the help from fellow audio addicts from Austria and Scotland. Isn't it great when we can communicate and get a job done! More when I have them sitting on the deck.
    PRE
  8. #118
    Tonight's update - Pt XXXIV - Still chipping away... slowly
    The G99 continues to be a perplexing animal. I haven't touched it in 5 months as I decided I needed a rest and had other more pressing projects. I decided to start looking at G99 pictures today after a couple of threads appeared on Lenco Heaven with respects to the strobe and the speed selector both of which are not complete on my own example of the G99. Both of the threads yielded a great deal of important information with respects to the composition of the G99. The strobe housing had a mirror attached and the casing is a lot more complex than I expected so it looks like I may need to make a mould so that I can vacuum form something which resembles the housing, I can see this is going to be very hit and miss, more fun and games
    The strobe casing. I have some measurements so I "should" be able to make something similar.
    The speed selector is proving to be a little more difficult to complete. It turns out that I'm missing x4 screws and x4 grommets to help the speed selector. I do remember having a very small bag of spares so I'm hoping that these could be the long lost missing bits that didn't seem to fit anywhere. The screws should be pretty easy to replace but the grommets are going to have to be custom made or bought as spares from somewhere. I have already made a request over on Lenco heaven for help but if anyone on AOS can help then please send me a PM. Finally thanks to Xerox over on LH I now know the positions of how the grommets should be fixed once located.
    It also appears that Goldring had two versions of the speed selector. The early machines differ in that they don't have any cut out around the speed selector switch whilst the later G99 appear to be exactly the same as the G88. It looks like the early G99 top plates were "proper" G99's and designed slightly differently to later versions. The later G99's top plate may have been modified from left over G88 top plates and modded into G99's this may explain why the G88 plastic top cover fits perfectly on my G99. So whilst I'm no further far forward with finishing this project it has clarified a few things and made me realise I'm still missing a few bits and bobs. I'll now ponder how to make the strobe casing.
    Thanks for reading.
    PRE
  9. #119
    Cut the sections from clear acrylic sheet and bond them with 'Plastic Weld'.
  10. #120
    Thanks, never heard of "plastic weld". Must do some research. I've been threatening for ages to get a hobby band saw, this could be the tipping point.
    PRE
