Simon (Daisy), I looked at the specs for both your NAD and DAC - you can link them via a TOSLink cable which cost £1.99 from amazon.
Specifically your NAD has toslink out and your DAC has toslink in.
Not sure you will notice much difference vs just RCA from your NAD to your amp. For £1.99 it is worth a try.
Oh maybe I was not looking at the correct DacMagic.
If so scrub my previous post Simon.
The problem with dab is that the sound is generally compressed to the level of low quality mp3. There are technologies that claim to help with this, not sure if upsampling is one, but they often involve valves, maybe a valve buffer would improve things more than a dac?
DAB is typically 128kbps, big shame.
ive a small dab upstairs that gets a few channels but not much. it certainly sounds pretty compressed; more so than when is started. I can get 320 with internet and thats pretty good most of the time. Spotify is only 320 max and it sounds good to me. dunno if they alter it a bit to make it sound this way but not complaining. Much of the content is hard to tell from full red book
