Mine was a CDRW drive, but if you can find a cheap CDR only drive then that's fine as if you're like me, you'll not use it for writing discs anyway.
The iMac drive only reads CDs at x24 while most CDR drives now do over x40 with CDs. As a modern iMac can encode to lossless at x40+ realtime, the internal drive is really holding things back.
The reason the internal drive is limited to x24 is so it doesn't make the wizzing noise a drive running flat-out does and spoil the lovely Mac silence!!
Steve aka 'Twelvebears' (it's a long story)
System: Technics 1210 Mk5, Jelco 750 arm, AT33EV via MF X-LP2 Phono Stage, Oyaide mat and record clamp. SB Touch via Marantz PM-11S1 amp and Wilson Benesch A.C.T. speakers. Mark Grant cables and PS Audio Power Plant Premier mains regenerator.
(\__/)
(")_(")
