Results 1 to 4 of 4
Thread: Sparky Noise - Hope It's Not A Problem
    Default Sparky Noise - Hope It's Not A Problem
    While playing my left speaker just had a kind of sparky noise... not a very technical term I know..
    I've never heard this before so I rushed over to the system to see if the amp was ok and to check plugs etc
    I stopped the cd playing and checked all the connections and they are all nice and tight... I don't know what was causing the sparky noise.. amp, speakers, cd or dac or cables
    I've re-started the cd and the noise has gone... It really worries me what it was
    I have never taken the lid off the amp so maybe I will do that and Deoxit all the valve seats/pins etc
    Bev
    I would leave things as they are. If it occurs again and on the same channel, then I would suspect a valve is starting to misbehave.
    Thanks Barry
    All seems ok at the moment...
    Bev
    I'm Shaun.
    I recently had a problem with my few months old power amp that was a distinct fluttery sound. Took out all of the valves, put them back, problem gone.
    Shortly after that I had a problem with the same fluttery sound on my valve guitar amp head. Tried the same, same end result...!
    Voila...!!
