Results 11 to 20 of 23
Thread: Advice on record cleaning machine
    I'm Dimitris.
    I have an okki nokki, not bad at all ..
    actually it does quite a remarkable job ...
    the only issue I had was the liquid sensor (disconnect it) ..
    I read somehwhere that new o.n's dont have that sensor anymore due to lot of problems
    **btw in case someone has a o.n. with the sesnor
    I have mailed o.n about it and they said that its ok to disconnect it and they send me instructions on how to do it [if anyone wants I can mail him their answer]
    also DhtRob has a nice tutorial on how you can do it
    https://www.dhtrob.com/overige/okkinokki_repair.php
    Quote Originally Posted by gsq4848 View Post
    I have an Okki Nokki and have had no problems with its functionality. I don't find the level of noise to be anything other than one would perhaps expect when using a vacuum motor.
    +1
    Turntable : Project 2 Xperience Tone Arm & Cartridge : Project 9c Ortofon 2M Blue Phono Stage : Project Phono Box SE II Digital Source :Primare CD21 Integrated Amp : Primare I30 Speakers : ProAc 110 Headphones : Beyerdynamic DT770 Pro
    Revox A77 MK IV 2 track 15 & 7 1/2 IPS
    TEAC A-3300SX 4 track 7 1/2 & 3 3/4 IPS
    Akai 4000DS MkII
    I'm Allen.
    I have owned both the okki nokki and a Moth , The next level is what i saved up for a Loricraft PRC3 , silent cleaning is bliss
    I'm martin.
    Default Advice on record cleaning machine
    Hi all,
    Many thanks to one and all so it's seem that, Project, Moth and Okki Nokki in my price range.
    Martin
    I'm Julian.
    I thought there had been some design issues with the Project that had been discussed on this forum previously - I would check if those have been sorted out before buying...
    Sonore Rendu - Cambridge Audio Edge W - Sonus Faber Venere 2.5
    I'm martin.
    Quote Originally Posted by julesd68 View Post
    Hi Jules,
    Will check it out,
    Martin
    I'm Simon.
    There isn't anything wrong as such with the Pro-Ject. The early versions (first batch) had the vac armtube made of metal and also the socket it sits in made of the same metal - causing some to get stuck as some users didn't grease them up. Pro-Ject supplied new instructions and a pack of grease for the 2nd batch (which I have). I've had no issues at all with this.
    I believe it now comes with a plastic socket that the arm sits in - so no metal to metal contact anymore.
    The other small thing is the foam/pad on the clamps, they can soak up the solution and it can end up on the labels (which it should be protecting). Not sure if they changed this at all but it's not a huge issue if you don't get lots of solution right next to it. I removed them and used some thin o-ring material instead which is perfect.
    Other than the silent running I assume it does a better job of cleaning than the Moth and Okki Nokki ?
    So therefore condones it's high price.
    Akai 4000DS MkII
    It cant do a better job than a perfect job. Lol. My moth does, imo, a perfect job. Its only down side is it is noisy. Fluid is not expensive after the initial first buy tbh. Noise can be averted by earbuds. It goes both ways but you have to turn the record twice. Use an old cd to protect label from any accidental splashes. Unless you are doing it all the time its as good as it gets without spending more on it than your actual system
    I'm Bob.
    I'm very please with my pro-ject machine, very effective in reducing pops and clicks. Static doesn't seem to be a problem even several months after cleaning a record.
