Bel Canto S300i integrated amp with USB DAC and upgrades
Bel Canto S300iu with USB DAC and upgrades
Well know, reviewed and highly regarded.
This unit is in very good condition and comes with the original double box, manual and remote.
This unit also has the USB DAC input.
Upgrades to this unit increased the detail, extended the highs and bass tones are more defined.
Upgrades:
4 of the film capacitors upgraded to Jantzen Superior Z-Cap (2 of which are on the output)
Soundcoat applied to chassis
Speaker binding posts now CMC silver plated types
Output wire to speaker posts now Neotech silver plater copper PTFE covered
Fuses – 2 internal fuses now HiFi Tuning Classic Gold’s
amp 2.jpgamp 3.jpgamp 4.jpg£700 plus post.
Preamplifier Section:
Bandwidth • DC-200KHz
Volume setting for unity gain • 80.0
Signal to Noise Ratio @ 2 Volt RMS • >95 dB A weighted, 20Hz-20kHz
Input overload • 10 V RMS
Output Impedance • 500 Ohms Single Ended,
Input Impedance • 10K Ohms Single Ended
Maximum Gain • 20dB/10X
Maximum Preamp Output Level • 9.5 V RMS
Amplifier Section:
Power Output • 150W/channel 8 ohms, 300W/channel 4 ohms
Minimum rated load impedance • 4 ohms
Frequency Response • 20Hz-20kHz, +/- 0.5dB
THD+N • 0.01%, 1W, 1KHz, 4 ohms
IMD (CCIF) • 0.002%, 1W, 14:15KHz, 4 ohms
Output Noise • 90uV A-weighted 20Hz-20KHz
Voltage Gain • 27dB
Damping Factor • >1000
Output Impedance • <8 milliohms
Dynamic Range • 111dB
Output Connection • 2 sets Safety 5-way Binding Posts
Idle power draw • 15 Watts
Power Requirements • 100-120 VAC 50-60 Hz or 220-240 VAC 50-60 Hz
Dimensions • 8.5” W x 12.5”
Bump
Bump and back up for sale.
New price £620
Bump
Packed ready to go. On the bay with an offer pending. Superb amp - be quick if interested.
- You may not post replies
- You may not edit your posts
Forum Rules
