I quite agree that Marmite walkers crisps are a good decision, as I have also made this myself. However, an even better one was Burt's Guinness flavour - absolutely stonking!
As to the SL-P1200, I like it. It's a bit ragged up the top end but it's a fun listen, the bass is superb and it's such a lovely thing to use. Ultimately, my Marantz CD-94 does better it considerably in sonic terms, though.
Thanks for all the advice guys, as usual an apparently very innocuous question about what seems a rather minor issue raises a good debate!
I think I've been a bit stupid as having looked closer at the bolts in better light there are little raised dots on the inside, I'm wondering if they are actually torx or a similar type and my hex key just happened to work ok on the slightly less tight one. I've been told about a company called Clerkenwell screws so I might take that one in to them to see what it is.
I'm Deleted.
Oh, you can buy both hex and Torx as security screws with raised pins in the centre that require a hollow bit to remove them. If you take a decent picture with your phone camera (assuming you have one) and post it I (we) can tell you what it is.
Account Deleted
No these have little dots around the inner edge of the hole, I'll try and add a pic
I've had a look at the other side and I can't see the dots, so I'm wondering if the hex key has made those marks..
Struggling with the phone camera, but an back to thinking they are hex.
